01-28-2008, 10:51 PM
#21
Damn both of you. I had to get out of my hot tub at a balmy 101F to come inside to read this post.
You guys are killing me! But I love it.
Hmmm.... a bigger tank in the same location.
2006 RB50 6.0 Diesel
SMB 4WD
Amsoil
01-29-2008, 03:42 AM
#22
I asked this question to SMB some time ago. The 16-gal for a "50" is one tank and fits in the 10-gal spot under the couch, but they modify the metal frame so the extra gallons stick out the back in a visible way (if you have the bed platform out of the back. Doesn't stick out too much, though.
If you want 20 gal, they put an extra 10-gal tank along the right rear side of the van. encased so you don't see it. But it eliminates putting other options in the same location.
They sent me a diagram showing both options, but I can't find the diagram.
1995 Dodge 3500 5.9L V8 2wd EB-21 PH
01-29-2008, 03:43 AM
#23
01-29-2008, 09:42 AM
#24
After taking some more measurements I think I'm back to adding another 10 gal. tank to the right of the existing "10" gal. tank. I could squeeze a new 14.5 gal tank in where my existing "10" gal. tank is, but with a family of four expecting to have some extended times away from fresh water this summer I think 20ish gallons makes sense. I'll configure it so I can remove the additional tank if needed, but I suspect that once it is in I will leave it in.
Phil
Phil
- 2005 EB50 6.0PSD - SMB 4x4
01-29-2008, 08:22 PM
#25
Phil
Hmm, why not add the 14.5 gal tank, and move your 10 gal to the right as the temp? Then you get ~25 for the trip, and an improved 15 after the trip. You gotta buy one tank... so why not make it the 14.5 instead of the 10?
SMB 4WD
Amsoil
01-29-2008, 11:16 PM
#26
Contact El Monte Plastics at (626) 442 - 0162 and request a catalog . I would personally upgrade the existing tank to a larger size as opposed to a dual configuration as this will lead to twice the chance of leaking .
PS they are on Strozier Ave , El Monte Ca. The bulk of their business is for the RV industry and I have used them with success for 25 plus years
Greggde
01-30-2008, 08:10 AM
#27
The other problem with just replacing my original tank is that I would lose a few inches to the storage under the bed to the rear of the van. Not sure yet if that is a big issue or not. I know there are several times I have that area packed to the point it is a challenge to get the rear doors closed. A single tank solution would be the cleanest. I would still like to see photos of a 16 or 20 gal installation in a "50" layout. Would be curious if all the extra tank size sticks out the rear of the couch in addition to filling all of the space between the couch steel supports.
I hope to get my plan together this weekend.
Greggde - Thanks for the info on El Monte Plastics. I have found several places on-line, but always prefer a good referral.
Phil
Phil
01-30-2008, 08:20 PM
#28
additional water tank
Phil, There is a photo that Greg took of a 16 gal tank in a RB50 in my album. two photos, as a matter of fact. Hope that might help.
Philrod
'07 E350 V10 RB50
01-30-2008, 08:31 PM
#29
Thanks Philrod.
Phil
01-31-2008, 12:05 PM
#30
Phil,
Another good source for plastic tanks is West Marine. They will also have all of the plumbing items needed for a retrofit. Do you have one near you?
Chris
Chris/Ruth
2016 MBZ Sprinter 144" 4wd.
DIY
07 BMW 525xi wagon
