Old 07-01-2008, 10:03 AM   #1
NRL
NRL's Avatar
Send a message via Yahoo to NRL
Alternate Cooling - Portable Air Conditions
Instead of using the Starcool..
I use the 5000btu Danby Portable Air Condition to cool the Sporto. I selected the 5000btu model since it works well with the Honda 2000 Generator.
I have tried 2 other models and the Danby is the smallest of the 3. The other ones are the Sunpentown, and Toyotomi models. They work well also but considerably larger and heavier to carry around. I have this model: http://www.danby.com/product/SPAC5088/4
If your sportsmobile is properly insulated, (I make sure the front cab is isolated (front windshield with shade, side windows with thermal shade, and a thermal curtain from the back cab to decrease the sqft it needs to cool), you can cool it down as much as 18 degrees..
The Sporto is pitch black inside on a sunny day.
You can see the various models at: http://www.danby.com/products/air_conditioners
http://www.sunpentown.com/airproducts.html
I'm in Vegas this week and hooked up to AC power, the Sporto was 70-85 degrees inside and 100-108 degrees outside..
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
NRL is offline   Reply With Quote
Old 07-01-2008, 08:47 PM   #2
NRL: How do you vent it? Just curious because I've been considering getting one of these, too.
2006 Chevy Express with an SMB PH and DIY interior and DIY gear trailer
https://www.geocities.com/jetrier/vanBoatsBikes.JPG
DIYSMBWPH is offline   Reply With Quote
Old 07-02-2008, 08:55 AM   #3
NRL
NRL's Avatar
I made a styraform window template shaped like a D with a hole in the middle where the exhaust port goes through. It fits on the back window and the window is snug fit against the template.
The water tube goes out below between the two back doors closed.
Old 07-03-2008, 05:33 PM   #4
NRL: Great idea. So the fact that the window is only 2" or so away from the styrafoam doesn't hurt the performance? And your unit only has one tube, no input tube? If you get a chance to post a picture, that would be really helpful, but I think I got it. Thanks
