Tom
How many miles did you have on the bumper before you installed the hard plastic guides between the bumper and the bottom of the swingarm to help support the weight? I'm wondering how much the extra up and down movement and vibration contributed to your failure. I'm also wondering when Aluminess added these plastic sliders to their design. My new rear bumper came with them.
Like you, I don't really like the design of the pivot point bolt attatchment. That is one feature that Aluminess should look at. I also think they should come up with a better way to secure the two swing arms together at the bottom to help eliminate swing arm movement.
Aluminum can be used for this application it just needs to be designed properly with all the different stresses factored in. If it takes a thicker wall aluminum tube to keep it from bending so be it, go thicker. I'll stick with the lightweight aluminum.
This is a picture of the hitch pin I'm using to connect the swing arms together. Any way to eliminate vibration or swinging weight when the swingarms are closed would improve the design.
