Old 08-10-2012, 05:37 PM   #31
Re: Alumi-less
FWIW I have an all-steel Reunel tow-bumper with similar swing arms (also tire mount and baja-style box). I haven't had a pivot issue, other than I did not like hitch noise that was transmitted into the door, so I un-bolted the top pivot from the door, and it is all bumper-only mounted now. Even though it is steel, I still had the latch holes all wallow out, so the arms have some slop in them now. I will have re-weld those, and hopefully find a better larch setup (I'm thinking maybe even automotive trunk latches so I can pop them open from inside too).
One downside of steel of course is rust. I just plan on periodically painting mine. Although, I would eventually like it powder-coated to match the front Buck-stop. Also, last week I spent a full day R&R-ing the bumper, so could straighten the bumper's mounting brackets, which I bent in the fall (the van might have gone airborne when I hit a water-bar across the forest road at ~50mph, and there might have also been a loaded car trailer hitched to the back of my hitch rack, which was carrying an array of coolers and dry boxes, which was hooked in a hitch extension so said array would clear the tire and box ).
If I did it all over, I'm not sure I'd go with steel again. Plus, these vans can use all the weight saving they can get, especially towards the rear.
Old 08-11-2012, 08:46 AM   #32
BIGVANS's Avatar
Re: Alumi-less
Also on your Reunel bumper you will see that when they weld the long flat support plates to the upright tubes that pivot on the stainless support tubes they are not round tubes any more they are oval from the welding heat, this makes the latch holes wallow out faster.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 08-21-2012, 02:40 PM   #33
Zeta's Avatar
Alumi-less
Until I can do the big rebuild on the swing-outs, I installed one of these:
http://www.amazon.com/Avibank-Mfg-Inc-R ... +Grip+Long
I had to ream the holes to slightly larger than 3/4", but it made a noticable difference.
Z
http://www.tomsinclair.net
ImageUploadedByTapatalk1345581605.008111.jpg   ImageUploadedByTapatalk1345581629.088766.jpg
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 09-12-2012, 03:13 PM   #34
Zeta's Avatar
Alumi-less
WARNING!! Not for the squeemish.
Started on remaking my Aluminess rear swing outs recently. I'm using a couple of swings outs from RockSlide Engineering. They each have their own little axle and tapered wheel bearings so they can carry a good load.
You can't make vichyssoise without peeling some taters:
There is a steel substructure under the bumper. It bolts to the bumper bracket and to the bumper itself which is incredibly strong. Hopefully I'll have the rest mocked up this week. Right now I'm a bit tired of grinding--Aluminess knows how to weld aluminium!
Z
ImageUploadedByTapatalk1347484108.985522.jpg   ImageUploadedByTapatalk1347484165.164477.jpg   ImageUploadedByTapatalk1347484183.695808.jpg
'06 RB50 SMB Diesel
Old 09-14-2012, 08:01 PM   #35
notmiller's Avatar
Re: Alumi-more! (was Alumi-less)
Nice, Zeta! I still have the OEM bumper and consequently no spare, so I've been debating what to do for a rear bumper. I had been thinking about buying just the basic bumper with no swingouts and doing exactly what you're doing. Thanks for being the guinea pig! Can't wait to see how it turns out!
notmiller is offline   Reply With Quote
