Old 05-11-2014, 10:25 PM   #1
Tapatio's Avatar
Aluminess with Warn Zeon 12 Winch
In case anyone is considering installing one it fits but you need to buy the 36" relocation kit. I made a simple V shaped bracket out of aluminum and installed the control pack on the left side.
This winch draws a hefty 435 amps at full load so I ran 2/0 welding cable from the van battery to the back side of the bumper and then joined the 1/0 winch wires with Anderson Powerpole SB350 connectors. The connector will double as a quick connect for jumper cables also and makes it easy to remove the bumper if needed.
Callsign KK6GIY
Old 05-11-2014, 11:18 PM   #2
Re: Aluminess with Warn Zeon 12 Winch
Never thought of making the disconnect as a point for jumper cables. Well done!
Old 05-12-2014, 10:37 PM   #3
pinz712's Avatar
looks good.
pinz712 is offline   Reply With Quote
