I have a 2007 SMB RB and installed a Ford OEM hood bug deflector. I just noticed at freeway speeds a great deal of turbulence and hood shake.
I've checked the hood security and the installaion of the deflector and have started to think the deflector is the problem, not the hood itself. Anyone had this problem before?
Next step is to remove the delfector and test drive, but its a rainy Saturday in the PNW...
Are you talking about one of those tinted plastic deflectors that goes at the leading edge of the hood? If installed properly, I can't imagine that plastic causing much turbulence.
FWIW, I don't believe they are Ford OEM, though they may be Ford dealership sold and installed.
I had one on my 2008 and never thought it actually worked. I got a cracked windshield almost immediately after I put it on, but left it on. I eventually took it off for cosmetic reasons. After about 5,000 miles without it I just got a nice star in my new Safelite windshield ... such is life ... it's a big target. I like the looks of the 2008 grill better without the bug deflector ... which, of course, IMHO, doesn't really work. That said, it would stop paint chips right on the front edge of the hood.
Never noticed any turbulence problems. I did notice my hood latched a little loose and that was an easy fix by moving the latch on the van body down.
Yes, I am talking about the tinted deflectors - it could be that it isn't OEM, I dont recall the box it came in when I pciked it up from the dealer. I've installed a few before and this one had instructions, etc...no problem to locate and install.
Last road trip at 65 MPH or so, with a stiff headwind is when I noticed a buffeting and enough turbulence to cause the wipers to shake around in the stowed position, which made me lean forward and look over the hood. Thats when I noticed the aft edge of the hood shaking fairly violently. I pulled over and checked that it was latched and then checked for a loose rear bumber stop or some reason for the movement. There isnt really a stop or rest for the back edge of the hood.
Anyhow - I'll pull it off and go for a ride tomorrow. Just thought I'd ask around first.
