Sick! What is the material you wrapped all the pipe with? I assume it's to reduce heat?
It's a special heat wrap to contain as much heat inside the pipe. Its made by the same company that made the turbo blanket for the hot side. The blanket works so well you can put your hand on the hotside of the turbo after running it for hours. Great way to reduce under hood temps and helps with spool up.
SooooOOOOooOOOOoo she lives! But... she dropped a injector off the bat... DOA from the manufacturer... Third set in a row from Industrial Injection ive had issies with... So cab back up and new injectors from Swamps will be here tuesday next week.
