Re: Chair bracket removal?
It may be a bit of a crude solution for your problem, but you could just grind the heads off the bolts on the topside. A tarp or drop cloth and some masking would keep debris out of the interior, and two or three minutes with an angle grinder would have the seat base out of there.
If you don't have one yourself, most rental centers could hook you up with a grinder, or you could roll by any welding shop in your area with your interior pre-tarped/masked and for a couple of $20s they'd probably be happy to remove the bolts.
The bolts may be captured by the heat shield, but you could wait to remove them until your next major underside service.
Just my two cents.
Sam
2003 Ford E350 PSD, EB Cargo, Quadvan 4x4
