Old 06-14-2009, 08:34 PM   #11
Re: dead battery
Should I use a trickle charger or a float charger? Will the trickle charger ever over charge the battery?
parabellum is offline   Reply With Quote
Old 06-15-2009, 08:23 AM   #12
SheepShagger's Avatar
Re: dead battery
Float if they are dead, it will take a very log time with a trickle charger, but it will work.
The idea of a trickle charger is you can never overcharge a battery, but I have used ones in the passed that will kill a battery over time.
I use the BatteryTender brand, model designed for a motorcycles, on all my cars and bikes, they seem to work very well, never over charge, and are cheap.
They do have models designed for cars, but the bike ones are cheaper / smaller and work just as well for me.
Old 06-15-2009, 08:49 AM   #13
scatter's Avatar
Re: dead battery
SheepShagger's right on here parabellum. I use 'em all the time on everything from bikes, boats, quads, cars, and the van. Only way to go if a rig is going to be left for awhile. I use the solar ones from Harbor Freight in Baja where power is a problem.
Scatter
2007 RB50, 6.0
K1WGB
Old 06-25-2009, 11:06 PM   #14
Re: dead battery
It might be important to factor in the standard load that your van pulls while at rest. I have found that an alarm (and other minimal loads like detectors) can pull a specific amount over what some light weight chargers can put out. Slightly larger loads as compared to what the charger can provide will produce a draw (or loss) and eventually kill your batteries even though they are connected and operating. This is where a high tech multi stage automatic charger shines. These chargers only supply what is needed; no over charging or under charging. Most high end charger/converters do this. Obviously the house and starting batteries must be tied together by some means to keep both up to par. But I have used a 1 amp charger on my Impala (that has an alarm) with good success. The SMB is another story and I use the "smart charger" that's provided with the inverter to keep things fully charged. This is not to say a trickle charger will not work, only to understand the consequences. Just monitor it.
Old 06-30-2009, 03:15 PM   #15
Location: Rolling Hills, Mammoth Mountain, Coeur d Alene Idaho
Re: dead battery
FWIW-I have used the deltran battery tender junior 12-volt 750 ma battery charger on my 6.0 psd at home in Los Angeles as well as an Escalade and 2 ATV's I have in Northern Idaho during the winter for months on end and for the last 2 years they have all stayed perfectly charged.
2008 xlt 6.0 psd
Cali Native is offline   Reply With Quote
Old 06-30-2009, 05:53 PM   #16
winvest's Avatar
Re: dead battery
I plug my shore power in and turn my inverter to charge when leaving my van sit for any period of time.
'07 E350 4x4, voyager top, custom interior, prorock 60, arb front & back, aluminess front & back, hella lights, extreme air, braun wheelchair lift.
"Two roads diverged in a wood, and I took the one less traveled by. And that has made all the difference." - Robert Frost
winvest is offline   Reply With Quote
Old 07-06-2009, 05:17 PM   #17
Re: dead battery
The van is finally up and running. Since the van was under warranty I had Ford tow it to their shop. They jumped and charged the batteries for me, twice, yup it died again.
Since then I put in a trickle charger and all seems to be fine.
Everyone has been most helpful! Mahalo.
MCSporty
MSD
Canadian Quigley
ert01
