Originally Posted by chainsaw5vent
i stopped at the ford dealer the other day and discovered that they were
'red tag sales' on the 2008 e350 rb/w v-8 gasser. the prices on the lot ranged from 13k to 15k. miles on vehicles ranged from 12,000 to 20000.
interested in a diy project for the first time and saving $$$. may not do 4wd but will seriously consider the camburg type suspension for the adventure part of life. this would replace the '01 chevy 15 passenger family bus.
what are necessary drive train upgrades for 4x2 capability for light offroading?
If you do go with a different suspension system, keep in mind a vehicle lift can get complicated and expensive very quickly depending upon the amount of lift. At a certain point (not sure what that is on a van), you might need to get the driveshaft modified, a drop pitman arm might be required, and other steering geometry modified. A rear locker wouldn't be the worst thing, and depending on where you plan on traveling, traveling with another vehicle wouldn't be the worst thing.
I've seen 2wd vehicles safely go places I didn't think they belonged, but the most important factor is what's between your ears.
