Doghouse Console
I had to replace my doghouse console (just the cup holder/door part) since the door broke. While it's off, I'm considering adding some insulation for sound deadening and thermal resistance.
Yes, I know it's not as good as doing the whole doghouse but that's a project for another day.
Anyway, I have a lot of the bubble wrap foil left over and I can use that with some 3M adhesive to attach it to the inside. Or, I was thinking about using some household expanding spray foam.
Thoughts? Comments? Concerns?
Thanks!
