Old 12-09-2018, 02:43 PM   #1
Drivers Seatbelt Latch Tensioner Connector
Driver Seatbelt Latch Tensioner Connector
2000 e350 7.3 Driver Seatbelt Latch Tensioner Connector??
Where does this connector from the seatbelt latch tensioner get connected to?
I do not have any other connector under the seat.
Can someone trace theirs and tell me what harness it connects to
or if it connects to some module in the B-pillar on driver side?
If it is a harness that I am missing then part numbers would help me with what I am missing.
caortizemail is offline   Reply With Quote
Old 12-10-2018, 05:17 AM   #2
The mating part of that plug should be under the seat base somewhere unless its been removed or disconnected by someone? Is you dash light showing problems with the SRS showing? It should be with that disconnected.
The wiring harness is under the floor covering, the needed connector poking upward through a hole in that covering as you mention. It might be necessary to remove the seat base, peel back the floor covering to see what modifications have been done to the wiring harness.
Old 12-10-2018, 06:58 AM   #3
If you don't have it right there under the carpet then I'm betting your van didn't come with those seats.
