Re: Easy X-Guage for 6.0L
Thanks! I did:
Transmission Fluid Temp
Engine Oil Temp
Fan Speed Sensor (really just want ON/OFF...)
Gear (worthless, gives 1 for P)
Intake Air Temp 2
Boost
On Boost my resting value was 11.7, which is not on the list so I used FF8B, which is the corresponding value to 11.7 and it correctly reads 0.0 resting now.
Relooking at the list, I might add Manifold Air Temp, but I'll probably run MPG, Transmission temp, Water Temp and either Fan Speed or Boost on the 4th.
