Old 12-19-2016, 01:33 PM   #1
Exterior shower turn dial replacement
My 2002 Ford Smb cold side turn dial from my exterior shower broke off the other day. The threading on the dial cracked and a piece broke off. It's the one smb used to install on the van outside.
Where can I find a replacement dial or am I SOL and will need a whole new assembly ?
Old 12-19-2016, 05:22 PM   #2
They have those handles at Lowe's/Home Depot and I'd be willing to bet the inner part that you broke is available too. I think it's common residential stuff, not camper specific, but I also think the whole assembly is just fairly cheap unless it's a different kind than what I had. Here's one that might work, even if you just robbed the innards from it.
Rv Shower Valve Replacement
Old 12-19-2016, 08:25 PM   #3
gcvt's Avatar
Yeah, you can get a whole new setup for under $20...
https://www.amazon.com/Dura-Faucet-D...outdoor+shower
Greg
New van: 2003 E250 EB10
Old 12-19-2016, 10:55 PM   #4
Holy cow you guys are rad. Thanks
Old 12-19-2016, 11:43 PM   #5
gcvt's Avatar
Nah. I once thought mine was broken, but it was just the black o-ring so I swapped the o-ring from the hot side to the cold side since I only have cold, but I had scoured Amazon for replacement parts.
Hope you get it fixed on the cheap!
Greg
Old 12-20-2016, 09:18 AM   #6
yvrr's Avatar
We had the same arrangement on our 2001 SMB but the two-handle design was always frustrating so I replaced it with the single-handle style used on newer SMB.
This is a link to that project:
http://www.sportsmobileforum.com/for...rade-8803.html
Jack
'01 Ford EB50p Quigley 4WD
