Old 09-21-2017, 11:44 AM   #1
Jsweezy's Avatar
Ford Van 2wd Fox Shocks
Hey Everyone,
Just wanted to let you all know that I wanted a Fox shock for the front of my van that is 2wd and I ended up figuring out what works.
Fox Shock 985-24-045 with an ES11 bottom bushing/sleeve combination.
It is about 1/2" too short at full droop but if you have 2wd, your not going to be jumping your van anyway. And if you do end up jumping your van I am sure the shocks will be the last thing you worry about.
You can order the shocks online but if you want the bottom sleeve bushing its a little harder to get. I go through Mark of Marks Sand Trans in Forest Grove, Oregon and he said he is more than willing to order and ship the shocks/bushings/sleeves anywhere within the US.
Old 09-21-2017, 11:46 AM   #2
Jsweezy's Avatar
Here are some photos...
Old 09-21-2017, 01:39 PM   #3
Originally Posted by Jsweezy View Post
...but if you have 2wd, your not going to be jumping your van anyway. And if you do end up jumping your van I am sure the shocks will be the last thing you worry about.
Clearly, we haven't met!
Old 09-21-2017, 01:58 PM   #4
good one QUOTE=TheLetterJ;212455]Clearly, we haven't met![/QUOTE]
Zappo is offline   Reply With Quote
Old 09-21-2017, 01:59 PM   #5
Thanks for sharing
Old 09-21-2017, 03:18 PM   #6
Jsweezy's Avatar
Pics or it didnt happen!
I ended up solving the problem with some custom fox spacers...
Old 09-22-2017, 11:28 AM   #7
Jsweezy's Avatar
UPDATE!
After further investigation, there is actually a more appropriately sized shock for this application.
Fox 980-24-663 with an ES11 Bottom bushing/sleeve would fit exactly the way it should.
Old 09-22-2017, 06:17 PM   #8
simplesez's Avatar
UPDATE!
Recommend you update/revise your first post with new info. Most people browsing do not dive into the post responses. Cheers!
Old 09-22-2017, 06:26 PM   #9
Can confirm. Shocks won't fail first when jumping the van. I had a pretty hard hit on the dirt road between Agness and Powers. Forest Service put in a giant new water bar across the road, which I hit at about 50 MPH in the dark. With hitch rack and trailer, both loaded. It bent my 20,000# rated Reunel hitch bumper at the brackets. The landing was hard enough the front bumper dug in and showered the windshield with gravel.
Old 09-22-2017, 07:10 PM   #10
Jsweezy's Avatar
I am going to have Mark at Marks sand Trans actually put his hands on one and make sure the measurements I have are the same as the actual ones and if so then ill update the initial post.
Thanks for the heads up!
