Old 09-05-2018, 05:24 PM   #1
bigriver's Avatar
Frame mounted Air Comp
I'm finally replacing the $89 air compressor I mounted on the frame 12 years ago (pic). It was adequate for re inflating the 285's (yes... quite slow) but won't budge the 315's. I bought the Extreme Outback Extremeaire Endura to replace it. 100% duty cycle and submersible (or so they say). I have a splash shield in place now that has worked very well for the old comp that I will keep in place for the new one.
My question - I want to run a line to the back bumper for a connect for my coil hose. What hose has anyone used between comp and connector. I have read guys will use steel braid at the output to minimize the heat transfer from comp to plastic/rubber hose.
Any thoughts/suggestions appreciated - Joe
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
Old 09-05-2018, 06:41 PM   #2
Bbasso's Avatar
At my place of work we use continental rubber (air) black hose and never had a problem.
I don't see a need to over think this.... K.I.S.S.
Rob.
Current:
And had three other E350s...
Old 09-05-2018, 08:56 PM   #3
larrie's Avatar
You can get a good idea of what is available for hoses and fittings from the Viair website.viaircorp.com.
Larrie
Old 09-06-2018, 09:08 AM   #4
REDOVAL's Avatar
I have a ton of experience with air compressors (air ride on mini trucks) and never had any luck with regular air line exiting a compressor. Anything with a 100% duty cycle will obviously run hot and needs the support of a steel braided or vented output line. I'm currently running a Viair 444C unit on my van as a backup to my primary CO2 and it works fine (albeit painfully slow compared to CO2 or my mini truck's belt driven unit). I relocated the air inlet to the engine compartment above any potential water line so it could be submerged and survive.
I would also recommend a deflector or shroud to go around the head/heat sink area of the compressor as it can get packed with mud in that location (edit, I see you have this...). When packed, the head no longer has proper thermal dissipation and will overheat the cylinder and fail the piston ring/seal. I found out the hard way on a very expensive and beautiful AZ compressor. This is on my to-do list for the unit shown below; I rarely use it for more than the locker these days.
Scott
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
Old 09-06-2018, 09:12 AM   #5
I’ve never had a problem with the hard plastic black stuff that comes with most compressors. Any big truck ship will have it. It is run all over semi trucks.
Old 09-18-2018, 04:37 PM   #6
bigriver's Avatar
Think I came up with a pretty clean way to mount the AC switch and outlet. My 25' coil hose reaches all tires.
Thanks for the replies. Joe
Joe
2003 EB30 - Sold
Old 09-18-2018, 05:16 PM   #7
geoffff's Avatar
I'm curious, why no tank?
I have a 4-gallon tank in there so the air flow is highest (when I hear the compressor cut off at max pressure) so I don't have to crouch down there at the tire so long. I have a 3-foot line (you can see it looped up) to let the air cool coming out of the compressor.
Or do you use locking clip-on chucks?
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 09-18-2018, 06:00 PM   #8
bigriver's Avatar
I thought about a tank - that's a pretty cool setup - but really don't need it for what I'm doing. I do use a locking chuck - makes it much easier. Joe
Joe
2003 EB30 - Sold
