Espar Gasoline Heater
Voltage (DC) 12
Heat flow Small Medium Large Power
Heat flow (btu/hr) 2,900 4,100 6,150 7,500
Heater air flow rate (cfm) 19 27 40 48
Fuel consumption (gal/hr) 0.026 0.04 0.06 0.07
Mean electr. power (amps) 0.67 1 1.9 2.8
Weight (lbs) 5.9
Size (inches) 12.01 x 4.53 x 4.81
Price Over $2000
Wabasto Gasoline Heater 2000ST
Voltage (DC) 12
Heat flow Partial Full
Heat flow (btu/hr) 3100 Variable 7000
Heater air flow rate (cfm) 37 Variable?? 55
Fuel consumption (gal/hr) 0.03 Variable 0.06
Mean electr. power (amps) 1.2 Variable 2.4
Weight (lbs) 5.9
Size (inches) 12.68 x 5.11 x 4.80
Price $2000 to $2800
This the best comparison I could do from their web sites.
Not sure if prices are for hardware or installed...
Think I saw some posts on high noise levels???
Are there REALLY fowling problems with calibrations (altitude vs sea lever). Although we are low landers I know we would get into the mountains for a few weeks on some vacations. Paying $2K to $3K for something and have it have fowling problems with "normal" use is ridicules.
Looks like the Webasto operates w an on-off switch only (?). Does the Espar use a real thernostat?
Other than being at SMB-I I have only seen two rigs (including my own DYI) let alone seen a heater, so I REALLY know nothing about them. Do not mind spending the money BUT I do expect what I buy to work. Not spend its time in a repair shop.
Sorry about the post I did put the info in columns for easy reading but all that went away when the message was posted.
