Old 01-18-2008, 03:00 PM   #1
pjpvi's Avatar
Heat management
To those that went on the DV trip, the photos are great! Wish I could have gone.
Who's beige van is it that has the hood / fender vents (Jeff?)? I'm curious how much improvement, if any, you found in terms of heat build-up in the cab after installing them. I've toyed with doing something similar, but they are situated forward of the engine and I'm not sure how much they would really draw the heat out. Any issues with water intrusion into the engine compartment?
Thanks -
Phil
Phil
- 2005 EB50 6.0PSD - SMB 4x4
Old 01-18-2008, 03:32 PM   #2
This thread may help shed some light on the louvers.
http://www.sportsmobileforum.com/viewto ... ce&start=0
I'd like to see some air exhaust temps from those louvers. Jeff, do you have an infrared thermometer, and can you get some measurements?
Old 01-18-2008, 04:05 PM   #3
pjpvi's Avatar
Ah, I remember that thread.
Jeff, any updated thoughts on the effectiveness of your louvers? Could you post a couple photos of the louver installation?
Phil
Phil
Old 01-19-2008, 06:43 PM   #4
Van runs hot
Phil
Since I last posted I put bigger louvers in the hood and put a 16 inch fan underneath the louvers. That fan sucked some major hot air out the hood.
However I removed the fan because I thought it was hitting the radiator hose.. I also put a 4x24 scoop underneath the bumper.. My thought on this whole deal are;
The louvers look cool.
They do let out hot air.
They make me feel better.
BUT...... I don't think it runs cooler. The fan comes
on just like without the louvers. I do think
it runs cooler at slow speeds.
I have oil temp gauge, trans temp gauge and engine water temp gauge.
It runs at 200 or 215 under any load.( max 232 ) Oil temp gets up to 220 at times. trans temp stays under 215.
I do run it hard, 75 to 85 MPH ( must be why I get 10 miles per gallon.)
Ford never designed this van for a 6.0 diesel. They run hotter than the old 7.3. As I'am sure you know the 2008 vans have a much bigger radiator and frontal opening...
Cheers
Jeff
P. S. I have lots of pictures but I cant figure how to resize them to fit on the forum...
P.S.S. I have some cool pictures of the 2008 Death Valley trip which hopefully you will see before 2009...
2006 Sportsmobile PSD-----69 Jeepster----BMW1200GS---450 KTM----450YFZ--- 2007 F150----2005 Nissan
myriadmyriad is offline   Reply With Quote
Old 01-19-2008, 07:22 PM   #5
pjpvi's Avatar
Jeff -
If you want to email some photos direct to me at phil@pacificventures.net would be great. I can resize and post here for anyone else that is interested. My interest isn't so much for the engine to run cooler (actually, just wish my engine would run at all now .... but that is a different story), but to help keep the engine compartment cooler which in theory would keep the cab area cooler.
Can't wait to see more photos from the DV trip!
Thanks -
Phil
Phil
Old 01-19-2008, 07:32 PM   #6
Van running hot
I have some pictures at my web gallery.
gallery.mac.com/myriadmyriad
Old 01-19-2008, 08:38 PM   #7
pjpvi's Avatar
Great pictures Jeff. It's all about the toys. Love the Jeepster project.
thanks -
Phil
Phil
Old 01-19-2008, 09:48 PM   #8
Hood vents
As to the water issue, I have a piece of plastic I tape over the louvers. It doesn't rain much in southern Nevada.
Jeff
