Re: House battery install
The house battery charges from the alternator when the starting batteries are charged and the seperator will then switch over and charge the house battery. That works fine, but I'd charge it before you install if you have a decent charger with enough amps to do the job. The other way would be to install it and then connect to shore power. I believe your SMB installed inverter/charger will do the job for you. I'd leave it connected overnight for sure. That should do it. It should be fairly well charged when you buy it, and just need topping off.
Scatter
2007 RB50, 6.0
K1WGB
