Old 06-11-2010, 04:25 PM   #1
House Battery Project 3 of 3
Again, if you're looking for 1 of 3, you're going to be disappointed. 2 of 3 can be found here.
Don't have a lot of time for this, so the basics are:
1. The not so beautiful tray got even uglier when I had to recut and reweld for the Deka brand batteries, which are 3/8" wider at the BOTTOM then the Lifeline, even thought the tops match.
2. Moved and covered all the wiring in my under-cabinet storage
3. Isolated all the battery drains and installed switches:
a. Xantrex panel should be "off" (powersave)
b. Installed a switch in the BlueSky battery monitor
c. Dual switches in the top two fuses, which go to the propane and CO monitors (last photo)
4. I also pulled and tested the starter batteries, purchased in 3/2008- both tested bad and were 100% warranty
5. (not pictured) the Jeep battery also tested bad
6. After it was all done, buttoned up and siliconed the xantrex panel informed me "Battery Temp Sensor not detected". Arrrgh!
9500
9499
9498
9497
9496
9495
9494
9493
9492
9491
9490
9489
9488
9487
9486
9485
9484
9483
9482
9481
9480
9479
9478
9477
9476
9475
9474
9473
9472
Old 06-11-2010, 06:47 PM   #2
WVvan's Avatar
Re: House Battery Project 3 of 3
That's one serious looking floor jack!!
Open the pod bay doors Hal.
WWW.WVBIKE.ORG
