Great tutorial--no doubt
very helpful to those not accustomed to working with glass etc!
Since I'm in the glass biz I'll add a few comments aimed towards the neophytes.
BrianW does a great job here so I'm just adding a bit of info for thought. Mind you I've replaced these lites numerous times and sadly have broken my share of them too.
-Be very,
very careful to remove ALL butyl material from both the window AND door frame! This is vitally important, trust me!
-Use a sealant like silcone RTV in 10 ounce caulking gun style tubes, they're easier to dispense and just about as cheap as the smaller toothpaste-sized tubes anyway. I KNOW the butyl tape sealant requires no special steps but unless you're somewhat experienced with this whole process it's very, very easy to break your new glass. This is because the butyl tape deforms by design but offers resistance which can bind and twist the glass in a way that breaks it. I've done this myself before switching to the RTV sealant.
-Be certain to align the special bolts properly where the shoulders fit through the glass, assuring they're properly seated in the glass. This is just another pinch, break and "Oh, Crap!" point. Check adjoining lites to acquaint yourself with the finished look which is what you want to achieve.
-Tighten each nut no more than a few turns at first, just until you feel them begin to clamp or slightly resist further tightening. The pattern of tightening isn't too important, just that each bolt is drawn down somewhat equally.. Once the glass, its plastic spacer and sealant is compressed enough you'll feel the nut seat and basically "lock up" signaling its time to stop tightening! For this operation I'd use a nut driver or palm ratchet, nothing larger than 1/4 or 3/8 drive.
-A few days after this type of installation re-check your fasteners as they've been known to work loose. Whether using butyl tape or RTV the glass isn't in danger of falling out but good to keep the bolt/nuts tight anyway.
Hope this is even partially helpful, feel free to comment or question anything I'm posting here.
Great write up again BrianW---kudos!
