Old 07-21-2011, 01:26 AM   #11
Re: huge problems with the brakes...help!
Originally Posted by racrx451
well, we don't know what else it could be as we've changed everything that he thought was bad. I guess the valve runs the right and left side together, not front and rear. cross your fingers that this fixes it...
No, the proportioning valve does not affect left/right bias, only front rear. It does this based on rear ride-height. The ABS unit can affect left/right braking, but it does this by pulsing the brake pressure, so it would not ever block all pressure.
Old 07-21-2011, 09:44 AM   #12
this peritcular unit has the valve and ABS all in one. I will let you know what happens. maybe one of the sensors is bad up front causing the left to grab more??
racrx451 is offline   Reply With Quote
Old 07-22-2011, 06:04 PM   #13
Fixed! It was the porportioning valve. Stops perfectly now. Thanx for the ideas guys.
Bruce
Sboring35
quigley
4x4Ken
