Old 12-12-2016, 08:53 PM   #11
4x4sporty's Avatar
I then took out the table leg holder and drilled a 1 inch hole in the body brace where the table leg was installed. I then installed a 2 inch coupling and a 2x3/4 female pipe thread reducer then underneath I screwed in the 3/4 galvanized tee and ran a length of pipe to the holding tank and used a pipe to barb fitting and ran hose to a tee into my sink drain.
4x4sporty is offline   Reply With Quote
Old 12-12-2016, 08:56 PM   #12
4x4sporty's Avatar
On the bottom of the sink I used 1 1/2 threaded to straight fitting that goes into a 1 1/2 x2 inch reducer which is removable both from the sink and the coupling in the floor .
I can put the leg holder back in when the holding tank is empty and when tank is being used I put a boat plug in it to stop holding tank smell and cover it with a rug.
Old 12-12-2016, 09:02 PM   #13
4x4sporty's Avatar
Pictures of underneath
Old 12-12-2016, 10:32 PM   #14
That is slick. Congrats on thinking your way out of cutting another hole in the floor.
Old 12-13-2016, 10:29 PM   #15
Nicely done
Clyde
ormtnbiker
Van22
Van22
