Old 08-11-2017, 04:15 PM   #1
Marine Water heter
I have been looking into using a https://www.kuumaproducts.com/6-gallon heater in the new build. It has a built in heat exchanger and 120v 1500w element.
Anyone used such a heater in a build/thoughts on using one.
Price on a 6 gallon one is $250
hogasm is online now   Reply With Quote
Old 08-25-2017, 12:21 AM   #2
i used one on our build and it works great, simple install, free hot water.
Eatmorefish is offline   Reply With Quote
Old 08-25-2017, 10:04 AM   #3
Wow! That's a great deal!
Currently vanless. Weird.
Old 08-25-2017, 10:09 AM   #4
Flux's Avatar
So this little guy can use 120V or engine coolant waste heat??
<br>
Old 08-25-2017, 11:36 AM   #5
Yes
it is designed to use coolant to heat the water through a heat exchanger or via 110v.
I don't see why you could not also add a 500w 12v element like Scotty has done and you would be covered by most of the bases
Old 08-25-2017, 11:53 AM   #6
I've been putting these in boats for years. They come with two different casings, one galvanized, the other stainless. Galvy is cheaper. In the van build I took it out of the case, put the tank in a cabinet and stuffed it w insulation. Saved a lot of space.
Old 08-25-2017, 11:55 AM   #7
I should mention that my van was a passinger EB so I just used the rear heater lines to plumb the heat exchanger.
Old 08-25-2017, 11:10 PM   #8
Originally Posted by hogasm View Post
Yes
Not me, did you mean Scott (Boywonder)? I'm I'm pretty sure he did that.
Old 08-26-2017, 12:38 AM   #9
I think you will want to add a temp. mixing valve because the engine heat will make the water very hot. Set it to a nice temp so you don't have to waist a lot of water getting the temp set right.
2015 Promaster Sportsmobile
KB2ZE
Old retired IBM Engineer
DCHitt is offline   Reply With Quote
