Old 07-14-2013, 04:17 PM   #11
Re: Exterior driving light/Golight mounting bracket for roun
Maybe take a look at commercial van roof rack bars and mounts. They are pretty sturdy, bolting onto the rain gutter in the same way the 'Z' brackets do and are designed for rigidity and heavy loads. You might have to buy 2 but after you show us fotos of how good your van looks, it shouldn't be hard to find a buyer for the other...
Yakima, and probably Thule and others also make low profile mounts that bolt into the sheet metal of the roof. That might be an easy way as well.
Old 07-14-2013, 11:38 PM   #12
Originally Posted by daveb
Why the movement? Too small of a surface clamp? Is there room to add a second bar behind the first and lash them together?
SMB has installed a similar bar I've seen made (I think) by Aluminess that looks very sturdy.
The end brackets that grab the rain-gutter are sturdy.
The bar itself is too flimsy. I believe its rated for less than 5lbs total and each of my lights are probably 3-5 lbs. should've done my homework.
Old 07-21-2013, 10:46 PM   #13
OCMB if the bar is sagging try to add a piece of 3/4" aluminum "L" metal to the light bar that will give it the added strength and make it riggid. You can get the metal at Home Depot
rawdawg is offline   Reply With Quote
Old 07-22-2013, 01:02 AM   #14
Thanks Raw.
Most likely gonna have Aluminess fab me a black powder coated light bar that can handle the weight.
Old 07-30-2013, 11:08 AM   #15
Re: Mounting exterior driving lights and GoLight
Try Baja Designs for your light bar needs , everything they make available is designed for off road/racing use www.bajadesigns.com and they are in San Marcos , Ca you can access some ideas in my gallery .
Greggd
Old 07-31-2013, 03:38 AM   #16
Originally Posted by Greggd
Try Baja Designs for your light bar needs , everything they make available is designed for off road/racing use http://www.bajadesigns.com and they are in San Marcos , Ca you can access some ideas in my gallery .
Greggd
Thanks!
They seem to have some quality accessories.
