Thanks for the links Jeff, I ended up picking up a 1.5” Bladex waste gate valve with 2 flanges to fit on either side to try out, like the ones used for dumping grey water. I’ll place this up in the pop top so we can regulate the flow from there. I’ll post pics when I install
Speaker box build....
Did I already post this? Anyway....
The speaker pods I had ordered were just too big and bulky to be mounted below the platform bed. I went back to the drawing board and decided to utilize the speakers I had, but still wanted them up and out of the door. Here’s the solution to be mounted up below the platform, the box does not go below the rear trim, so things are tucked up nice and tidy. I incorporated an open center shelf between the speakers.
Getting wrapped with foam and fabric
Front lip so things stay put, this is the orientation as it will sit up against the bottom of the platform, the back gets captured by the rear trim
Tipped up to see where the speakers will go
Like this
New rear ceiling platform piece getting wrapped and trimmed
Closeup of how the corners get finished
And trimmed
I’ll get this all installed hopefully tomorrow, so it’ll all make more sense where it all goes.
