Old 09-19-2019, 06:25 PM   #11
We put down commercial quality carpet tiles in our motorhome, They're tough and relatively inexpensive. Order extra in case you need to replace a tile here and there. They're also easy to fit when installing since you're not handling a single big sheet. We used carpet tape for installation but commercial installers use some sort of glue than allows removal for replacement.
Bob
2002 Itasca 35U Motorhome
BCam is offline   Reply With Quote
Old 09-20-2019, 12:47 PM   #12
flooring
I have the original SMB installed (15 yrs ago) marine vinyl with their commercial type removable carpet over that. I very seldom remove the 2 carpet pieces. The carpet is easy on the knees and easy to clean using one or the the other of two corn wisk brooms noted below. Depends whether top is up or down which one I use. Good for the front too.
https://www.amazon.com/Small-Whisk-B...9004520&sr=8-4
https://www.amazon.com/Rubbermaid-Co...XY3SV09HMARBB5
wahoo is offline   Reply With Quote
Old 09-22-2019, 05:01 AM   #13
I used something similar in my work van---this was left over material from a retail space rehab so its designed for high traffic areas. I use what's generically known as "pressure sensitive adhesive" like this: https://www.robertsconsolidated.com/...ve-adhesive-2/ Its easy to use over most any substrate, can be applied so it holds the covering in place but allowing for easy removal at a later date.
That's just one brand but certainly not the only one available. Find it at Home Depot et al---should be available in 1 quart packages.
Naturally you don't need a whole gallon--two quarts would do most every van floor. I bought a full gallon container, used maybe 3/8ths of it and 5 years later it was still usable.
Its a product worth looking into I think.
HTH
Old 09-22-2019, 09:18 AM   #14
Fool120's Avatar
We too have the original SMB floor with detachable carpet, yet only use the carpet in the winter, when it's cold out. We usually are in some dirty, dusty place, and end up getting all that inside the van.
Rob
'97 Ford E350 EB 7.3 PSD
Quigley, Sportsmobile
Fool120 is offline   Reply With Quote
Old 08-09-2020, 10:43 PM   #15
Originally Posted by mgmetalworks View Post
The vulcanized rubber mat we've been using for floors works great. Very durable, easy to clean and forgiving on the knees and feet. The difference between this and horse stall or gym floor mats is that it isn't porous.
Product is called "Stamina" from NW Rubber Products.
Hey there, Rob in Aumsville here. Looking for this Stamina product, but can't seem to find it at NW Rubber Products retailers. Can you help point me in the right direction? I was just about to go with the coin flooring but this looks like a better option.
Thanks!
FRMNRB is offline   Reply With Quote
Old 08-09-2020, 11:23 PM   #16
https://northwestrubber.com/sportflo...ducts/stamina/
Chinook is offline   Reply With Quote
Old 04-19-2022, 07:02 PM   #17
Interesting material. I realize I'm resurrecting an old thread, but did you end up installing the 2tec2 flooring?
Viajero69 is offline   Reply With Quote
Old 04-20-2022, 09:34 AM   #18
Second on the 2tec2 flooring I used loncoin and wish I had gone this direction. So much better looking than the loncoin
Lcavalletti is offline   Reply With Quote
Old 04-20-2022, 07:58 PM   #19
Mikerson's Avatar
How about woven vinyl? Has a padded backing…easy to clean…doesn’t hold sand.
I recently got a sample. Was thinking for my boat, but then saw your thread and thought it could be good in a van too.
https://youtu.be/evlYtcrzunI Skip to the 1:30 mark to get past the dumb intro stuff.
Mikerson is offline   Reply With Quote
Old 04-20-2022, 08:10 PM   #20
Mikerson's Avatar
Quick pic of one of the sample pieces.
