Originally Posted by jage
Does SMB or Quigley change the rear springs when doing the conversions? I would think that stock springs with the SMB build would not only ride better (not the case in my van) and be able to handle the load without being on the overload springs 100% of the time (also not the case in my van).
Yes the rear spring pack is different on my 06
EB and is not stock. In fact it has a partial military wrap backup spring.
Pat, SMB had changed the rear pack in later 05
(I think) due to complaints about rear end sag.
(John K should know). Although my vehicle never did have rear sag even when loaded, I had rear air bags installed just in case. My van is 12K lbs loaded and in 06 it was between 10.5 and 11K when loaded back then. Several owners had an extra leaf or two added on their 4x4's to offset the sagging problem probably more for cosmetic purposes but also for future extra loads. Just before the new 08 came out I think SMB was on the issue for the most part, so the 07's should sit level at least. The 08's are quite different but might suffer from stiff ride (someone with a 08 would have to comment here). I would think Jage is correct on adding a leaf = stiffer ride. My 06 rear spring pack is stiff enough and I would not want to jeopardize the ride by adding a leaf. But your vans total weight could make a difference I would think. Your mileage might vary due to the vans weight. It's going to be a gamble going to Deavers in the rear of my rig because I don't know what I'm gonna get for the money. I might not see that much of an improvement and I just have to take the plunge. Owners claim Deavers should allow more flex for a softer ride, less rear end bounce and an increase in height by about 2 inches. I have no sway or cornering issues but I'm hoping that Deavers can help with bounce. I'm sure some is a shock issue also and I'll probably switch to Bilsteins. Most of my problem is in the front with washboard shutter. It’s wicked. BTW when I'm on a rough road, pumping up the air bags makes the ride rougher so I let them down to 10 or 15 lbs and let the springs absorb all they can. Also when I went to E-rated tires it became absolutely necessary to air down on rough roads. Now that I'm running E tires I'm thinking the drive down south might be worth it. Air bags have problems with leaks and don't last forever. Maybe you can speak with Deaver to see if they can custom build them like Jage said. Just weigh the axles and each tire (corner) on the van and give them the necessary info. Sounds like Deaver has done enough SMB's to be on top of them.
