Old 02-07-2012, 02:11 PM   #1
Onboard Power Welder install
Anyone have experience with installing a power welder to their van?
carl
2010 SMB
Old 02-07-2012, 03:07 PM   #2
Re: Onboard Power Welder install
Just read about a few alternators that allow crude welding and have seen some aftermarket kits. I figure driving in a mechanic to fix something on my engine will be more probable than needing to weld something. Hope I haven't jinxed myself
Old 02-15-2012, 09:53 AM   #3
Do you mean one that runs from an alternator? I imagine you'd have to either isolate your van's electrical system, or add a second alternator that could be isolated. Guys often use a big truck 24v alternator, one with an external regulator so you can get around it. Finding somewhere to put it can obviously be a problem. Seems like a lot of effort unless you're using it frequently, but if you need a second alternator anyway it could be worth it. Check over at jeepforums.com.
I've seen guys use ReadyWelders; they're constant voltage so you just hook it to batteries, usually a few if you need to weld anything even slightly thick. There's an instructable out there that shows how a guy bought a used spool gun off eBay and hooks it to batteries to accomplish the same thing.
Of course people weld with sticks off just about anything. You might even be able to find some sort of control board out there so you could try to regulate the current and/or voltage, or you're stuck with output that might make for only emergency welds.
Rob
Old 02-16-2012, 04:25 PM   #4
http://www.nationsautoelectric.com/Priemerwelder.html
Old 02-16-2012, 07:40 PM   #5
Bones_GSXR's Avatar
I used to have a Premier on my Landcruiser. Worked well and I did not need it very often.
