Old 07-29-2013, 11:21 PM   #11
mmocken's Avatar
Send a message via AIM to mmocken
Re: Penhouse window cracks
Hard to see crack in plastic in picture...it is a horizontal crack towards the bottom of the window
Delamination is clearly visible, I assume to re-iron it will repair delam
One nice thing about the fabric patch, it provides a little more privacy by blocking the lower half of the window, yet lets most so the light through
Thanks, Marty
Marty's 'BearsMobile'
1995 Dodge SMB EB-20 + modified for shower in back, PH Microlite Starcool. 130k miles young!
https://www.sportsmobileforum.com/alb...a37caeae3a.jpg
mmocken is offline   Reply With Quote
Old 10-27-2013, 09:15 AM   #12
moorefc's Avatar
For smaller cracks and repairs, vinyl repair (home depot or ace) has worked well. It seems that sunshine over time tends to brake down the screen. Using this with toothpicks etc a fine line can be created that bonds nicely. The window material can fail on the stitching in the corners probably due to the weakening of the material by stitching and corner stresses. The vinyl repair works very well (invisibly) for that. It has lasted for years without sign of weakening.
I suspect Sportsmobile has the top warrantied, not necessarily the windows/screens.
The other item that helps windows is using Aerospace 303 Protectant http://www.firstchoicemarine.com/p-1242 ... 30340.aspx ,
a water based silicone on the plastic and zipper teeth. It took a bit of research to find what this is, and the key difference is this is water based, rather than solvent based. It is used extensively in the marine industry (West Marine, Amazon etc). It appears to make the vinyl more supple and the zips are very smooth! Freezing camping window zipping used to be a concern...
Pac NW and warmer places
2006 E350 EB Elect Top 2WD
moorefc is offline   Reply With Quote
