Dorothyt7's passenger pivot bolt broke, and sheared the front bar roof block. In the pic one can see the marks where the bar force sheared the staples. All better, both pivots replaced...Lasted from 95 to now, so locally sourced grade 8 bolts trimmed to length made it pretty quick fix. Interestingly, the bolt broke at a non load or wear contact point...fatigue....The other side bolt looked good tho slightly bent..
Bonus was a link tighter on the spring tension made the top raising a bit spritely..
