09-15-2018, 11:54 PM
#31
Gone Traveling
Wow.. that was some job you did! And I was really interested in seeing what the roof looked like above the interior ceiling... i’m not asking this in a rude way, but was your canvas always that wrinkled and uneven/crooked, before you separated it from the ceiling? Or was putting it all back up into place what caused that? I ask because mine is brand new, and it is so crooked and wrinkled that I can’t unzip some of the windows without lowering the top at least a few inches...
But again, kudos on tackling that job!!
09-16-2018, 10:11 AM
#32
I don't think anything chaged in how crooked anything is. I have never had a problem with windows opening or anything like that. I don't generally want it to be completely taught in the raised position, as it moves in the wind, sometimes tilts slightly if not completely level. To be honest I have never few it as a problem.
09-16-2018, 01:27 PM
#33
Gone Traveling
Scalf77, Thanks for the insight!
09-29-2018, 11:55 PM
#34
I'm about to start the process of redoing the headliner and I have a couple quick questions.
Did you remove the old headliner entirely and then reattach the sides or did you remove the headliner in pieces and reattach the sides as you went?
Did you notice any wood rot where the bolts pass through? I'm worried mine might be a little bit. If so, any tips for repairing that?
Thanks!
1990 Chevy G10.
DIY camper build with 70's custom van influences and far too much faux fur. Simply known online as #DereksVan.
09-30-2018, 07:27 AM
#35
I removed the old headliner completely, used it as template.
Yes, I did in the front holes. I actually removed rot with dremel tool, and filled with epoxy. I also reinforced the bottom with resin and cloth.
09-30-2018, 09:05 AM
#36
Thanks for the response Greg! That was my plan as well so it's good to hear it works.
1990 Chevy G10.
09-30-2018, 12:53 PM
#37
Derek: If you are going to go through the aggravation of removing the canvas when removing the headliner, consider making plywood strips to re-attach the canvas. This makes headliner activities (like running solar wires, etc) much easier later.
Here's my build thread; headliner activities start at post #18.
http://www.sportsmobileforum.com/for...p-10808-2.html
...and one other thing.....if I was doing the headliner again I would do it like Greg did in this thread.....have one seam under one of the padded blocks on the ceiling....this hides much of the seam.
10-01-2018, 01:26 AM
#38
Absolutely! The strips seem like a huge improvement and absolutely what I'll do. I've read your build thread a few times though now. It seems like one of the few that really documented installing the roof which I've just completed. I used the corner brackets like you did, so thanks for that as well. Now that the swap is done I'm looking at improvements and repairs.
1990 Chevy G10.
