Re: Penthouse Install - Fresno SMB (not optimal)
Has anyone tried to use the heater fan in the vent position with the windows and doors all closed in the van. The increased air pressure would make the top much lighter going up. I had a guy with a pickup pop top tell me he used that trick.
