Originally Posted by LenS
Took a mirror out to the van and checked the scissor bolts on my Indiana installed penthouse top (2008). They are grade 8 bolts (have six bars stamped into the bolt head).
Anyone who has had penthouse bolts break it would be of interest which of the 3 SMB plants installed your top. Also it is important to check the failed bolt grade markings.
Also could see the bolt head on the forward scissors end and it also is a grade 8 bolt. Can't chk the chain/spring attachment bolt but will assume it is of similar quality.
Feel fairly comfortable now about the scissors lift mechanism.....unless someone who has had a scissors bolt failure reports that theirs was a grade 8 bolt that failed
I just checked mine and it seems to be grade 8 bolt as well. The plastic washer in between the bars isn't looking too great though. It's been ground down on either side to hug the bars. How tight should these be bolted? I found the nuts on mine had almost backed off
and I tightened them until they were pinching the plastic washer in between. Here are a couple of pictures:
