Old 11-30-2016, 08:40 AM   #1
Van Hulkn's Avatar
Exclamation Penthouse troubles.
So went camping in fort Bragg during thanksgiving encountered some good amount of rain and wind. I found I have a few leaks kind of bummed about that.. When the weekend was over I dropped the penthouse and went home. I wanted to dry the top out some so when I got home I popped the top up. First thing I noticed was it didn't go up as easy as it usually would. Then when I wanted to drop the top it didn't want to go down at all. I really had to fight it so much so one of the handles broke off. Any ideas on what the problem could be? I drive this van daily so don't want to get stuck with this top up for to long.
Thanks in advance.
Van Hulkn is offline   Reply With Quote
Old 11-30-2016, 10:18 AM   #2
rallypanam's Avatar
Something got bound up/broken/jammed in the tracks.. so you'll need to raise the top, prop it up with 2x4s or something, and then access the tracks under the fabric in the rails.
There's a few good threads around here with pictures of how the tracks/springs/blocks work, so search for those and compare to yours.
Also, in general, try not to force the top! If it won't go up or down, there's a reason, and forcing it will generally make it worse!
Old 11-30-2016, 10:37 AM   #3
Some things to look for are bent bows, and possible a sheared bolt that the two bows connect and pivot through.
Old 12-07-2016, 11:49 AM   #4
Van Hulkn's Avatar
No idea what the problem was. Got all ready to work on it this weekend and it was working fine. Checked the rails for anything that should not be there and nothing.Springs looked good as well as the pivot . The top went up and down many times and was smooth as always.
Thanks for the replies.
Old 12-07-2016, 12:03 PM   #5
Flux's Avatar
So you fixed it.....nice!
Old 12-07-2016, 02:04 PM   #6
danamrak's Avatar
It fixed it self..... glad it's working for you now.
Dick and Anne
DABEE a 2006 Ford EB250 with penthouse top.
Life Is Good.
danamrak is offline   Reply With Quote
Tags
broke, penthouse
