Old 10-13-2014, 12:00 PM   #11
E350's Avatar
Re: Quixote Van design concept
One idea from tecnodave:
http://store.mwands.com/dc-water-heater ... r-element/
Old 10-13-2014, 12:39 PM   #12
Ah yes, use the heater drain fitting to install the 12 v element. You then keep the 110 v heating element for shore power. Trouble is the 112 v heating element is 1 inch pipe threads, not much chance of using the heater drain fitting (probably 1/2 or 3/4 inch).
Quixote2 is offline   Reply With Quote
Old 10-13-2014, 01:28 PM   #13
The Fiat Ducato produced in Europe has three roof heights; low, medium, and high. Ram sells the low and medium height versions. Ideally, the high roof version that offers a maximum internal height of 7' 1.5 " (85.5") would be better suited for a van conversion. Installation of a subfloor in the rear of the van, 8 inches high, provides additional space for tanks or storage while still maintain the 6 foot plus head room.
http://www.autoexpress.co.uk/fiat/ducato
This second link provides Fiat Ducato specification including Fiat's mpg ratings (note these are imperial gallons, divide by 1.2 to convert to US mpg).
http://www.fiatprofessional.bg/models/d ... ch_Spe.pdf
Testing
Tech Admin
LiamMobile
Shyll
