Originally Posted by pbjosh
Since the top is new and the butyl is new, I'm planning to just trim the butyl back to the washers neatly and shoot over the hardware except the little plastic covers. If anyone has a good reason to avoid lining the hardware I'd love to hear it!.
Josh
Just make sure you use an acid etching primer over the bare metal. I sanded the hardware to give it a bit more to bite on, then trimmed back ALL butyl tape, wiped off the excess with a thinner as well, then used the primer before any spraying was done. I also used some of the adhesion promoter in any area that was a bit shy on sanding do to odd angles and such. From U-pol It was the #4 adhesion and I think it was the #8 primer although most any real good acid etching primer will work. The one other extra bit I did (before all of the that) was to use a two part plastic epoxy material to create a raised area up to the new hardware then feathered it back out just to alleviate any chance of water to pool up and stand in the area of the washers. The only thing you can see now is the bolt head under all the raptor liner. Just waiting for a good rain to test it all.
I will try to post a picture when I have time to figure it out....again. lol
