Old 11-25-2016, 11:51 AM   #1
LandVan's Avatar
Rear Door hinges for E350
Can I swap out my rear door hinges so they open 180 degrees?
My 40% side door opens 180, can I use those hinges on the rear doors?
LandVan is offline   Reply With Quote
Old 11-25-2016, 12:01 PM   #2
1der's Avatar
The doors already can open 180 with the stock hinges , right? Release the door rod and the door will swing to near 180.
Old 11-25-2016, 02:42 PM   #3
^Yup. Just release the "door-check".
The newer doors have a 2-stage door check which doesn't not require releasing anything. Somebody on here looked into swapping that only, but apparently that isn't possible. Newer wrecking yard doors for a white van are probably a dime a dozen.
Old 11-25-2016, 02:48 PM   #4
Took me a while to realize that the rear doors on my Excursion also have a door-check.
Old 11-26-2016, 02:15 PM   #5
LandVan's Avatar
Thanks. I should have figured that out.
Old 11-27-2016, 03:13 PM   #6
Pntyrmvr's Avatar
Just keep your eye on the door the first time you open it fully without the limiting rod. I cracked a tailight lens with the spare tire.
