Old 07-06-2011, 08:58 AM   #11
ANZAC's Avatar
Re: Rear power inlet vs Aluminess rear bumper
Not sure it's a valid theory or not, but I picked up the habit of covering painted surfaces with painter's tape before doing any drilling or cutting. Maybe it's just an urban myth, but I've been led to believe that it helps prevent chipping the paint along the edge of the cut surfaces.
It also prevents dwarf from scratching it as it is dragged around by the saw.
Jage, do you have a good rear-on photo of RHS of brush guard? I think the joint of the vertical and horizontal post is right where the outlet is.
Also appreciate any photos of locations of anyone's power inlet. Some pictures I have seen put it close t the propane tank...
Maybe the owner had it put by the tail light for their parking space at home. At home I can make any location work.
Sportsmobile-less.
Old 07-06-2011, 09:41 AM   #12
Some in here: viewtopic.php?f=14&t=4482&hilit=my+rear+bumper+alu miness
I do think it's right where the Y comes in.
but there is a reason I shot the driver's side today:
Old 07-08-2011, 11:52 AM   #13
I do have mine in the propane door even though I don't have propane and its located behind the drivers door. If it was mounted in the rear or passenger side, I'm sure I would have drove off many times with it still plugged in. At least I don't forget to unplug cause I see it before climbing in.
Old 07-08-2011, 10:06 PM   #14
ANZAC's Avatar
I spoke with Peter at SMB a bit today. My SMB has the smaller side door (1 catch vs 2), which is full of propane/tank/gauge/valves.
My water inlet is on the rear of the left side of the van. I don't have any 110v outlets, no inverter.
Sportsmobile-less.
