Old 12-07-2007, 09:49 AM   #1
Rear Shower
The first use of the rear exterior shower was interrupted due to the shower assembly pulling loose from the mounting board. It is just attached with small surface screws which are too small or were overtightend during installation. I have been able to re -attach the unit by using the next larger stainless screw size. If this does not work for you, you can remove the cushion above and gain access to the rear of the assembly then drill the mounting board, and use small threaded through bolts and put nuts/washers on the rear side. Some lubricant on the plastic cover door of the shower assembly also will help relieve the pressure when opening/closing.
07 E-350
patrick51 is offline   Reply With Quote
Old 12-08-2007, 09:49 PM   #2
Did you burn your head off like I did the first time you used it? Wow it got hot fast! Too bad the controls are not on the shower wand head. DaveB
