Old 04-28-2011, 12:24 PM   #1
yvrr's Avatar
Refrigerator storage...
I hate to hear things rattling around in the refrigerator. We started out trying to solve the problem with some spring-loaded bars from Camping World but they didn't work very well. We then found some plastic storage trays which fit the shelves. That made it easy to store things but they interrupted the air flow in the refrigerator which wasn't good.
After replacing the original refrigerator with an Isotherm unit, we finally found some wire trays which solved the air flow problem. However, they were slightly narrower than the inside width of the refrigerator and therefore slide sideways unless they were completely full. That problem was finally solved with pieces of foam pipe insulation from the hardware store. The overall diameter of the insulation was slightly wider than the space between the trays...slicing the insulation lengthwise resulted in a nice tight fit:
No more rattles!
Jack
'01 Ford EB50p Quigley 4WD
Old 04-30-2011, 06:37 PM   #2
Re: Refrigerator storage...
The best thing to take up space in the ice box is wadded up newspaper. You can add or subtract as needed and stuff doesn't roll around. Plus the more stuff is in your 'frigerator, the less it has to work. A full frig' is a happy frig'.
Bill
NO2B
Old 04-30-2011, 08:03 PM   #3
WVvan's Avatar
Nifty idea
Open the pod bay doors Hal.
WWW.WVBIKE.ORG
