The install was pretty easy -- a couple hours' job. The two water pumps were almost identical in dimensions, so the new pump went in without rearranging any plumbing. The new pump came with all the screws, etc., needed for the install. The hardest part was figuring out how to get to the screws for pump removal.
- Drain the water tank.
- Remove old pump: The 2 plumbing connections unscrew, and removing the pump itself required some awkward screwdriver work, with extensions on my ratcheting screwdriver. I ended up unscrewing the mounting board from the Sportsmobile floor and taking it out with the pump attached. Two wires: one wire to cut (crimp connection), and one connection to pull off.
- Install the new pump: Again, screwdriver work, screwing in plumbing connections, crimping a wire, plugging in the other. There's an inline coarse water filter (screen mesh) before the pump to catch large grit, just like the old pump had.
I bought the pump from Tom Raper RV Parts
www.tomraperrvparts.com.
$83.01:
Part #86-8118 Whisper Kingâ„¢ Fresh Water Pump (2.0 GPM)
-- Geoff
