Old 04-02-2013, 01:24 PM   #1
audisnapr's Avatar
Roof Rack Decking
Gearing up for phase II of “EMT Gas Inhale”, otherwise known as homebrew roof rack following the homebrew ladder from 1” EMT. http://www.sportsmobileforum.com/vie...=7146&start=75
While doing my research I came across a deck material called PolyMax Kennel flooring. It’s a 2’x4’ polypropylene decking material used commonly in the farming industry for kennel flooring with chickens and other animals. Anyhoo, has anyone had any experience with this material, specifically used as a roof rack flooring? Apparently it’s a pretty common flooring material for DIY roof rackers, but my search on here came up empty. Each 1/2” thick, 2’x4’ piece weighs 8lbs and can be interlocked on the short and/or the long side. http://www.farmtek.com/farm/supplies...;pgha2215.html
My biggest question is the material’s spanning and weight capacity. Hoping someone might have first hand experience.
4amRacing
audisnapr is offline   Reply With Quote
Old 04-02-2013, 07:44 PM   #2
Tapatio's Avatar
Re: Roof Rack Decking
Looks strong enough to stand on as long as you have some lateral or horizontal support like in those pictures. I was thinking of using expanded metal but this might be a better solution. Just measured my Aluminess rack and it is 4' 5" wide from rail to rail.
Ask Zeta's rooster if he approves?
Callsign KK6GIY
Old 04-03-2013, 12:11 PM   #3
That looks like a smaller version of the stuff they use for cat walks and such in industrial settings; it's called pultruded fiberglass, although I think it's made with other materials as well (HDPE?). If you search around you'll find sites, and since it's used in flooring for people the specs are available. Not cheap.
And of interest is the fact that folks sell sections of it for use as sand ladders. It apparently works pretty well, although tests I've seen show it to be kinda bendy for bridging use. See http://www.okoffroad.com/stuff-waffleboards.htm for example. More spendy, but still pretty light (4'x1'x2" was 19 lbs) and you'd have a floor to your rack you could use to get out of a jam. But since they have to be OSHA compliant they tend to be strong but expensive.
McMaster-Carr also sells grated flooring of all different types; you might find comparable specs there.
I keep browsing Craigslist to see if I can come up with a pair. I once thought of making a rack out of aluminum sand ladders; they go for about $100 per 40"x16" length, at 24 lbs. So they might be a cheaper alternative, and just as light, since I assume you could delete some crossbar from the design. The vehicle that give me the idea just had two strapped to a yakima cross bar set, and didn't have anything very heavy on them (a truck, not a SMB). These might not handle the weight of a SMB if they have to bridge anything. I ended up using parts of a modular dog kennel cage; they were powder coated and fit nicely and readily available used.
