Phase 1: Vibration Damping Products for use on doors and any other sheet metal we can expose:
The unit is called Acoustic Loss Factor (ALF) which is the same as Damping Loss Factor (DLF). The range extends from 0 to 1, with 1 being the best.
Product name - ALF value; Price for typical purchase and amount of product; $/sq ft delivered
This is roughly in a ranked order quality which roughly correlates to cost:
1. damplifier pro - ALF?; $175 for 36 sq ft; $4.86
2. dynamat xtreme - 0.42; $140 for 36 sq ft (9 - 18"x32") ; $3.89
3. eDead 120 - ? ; sold by sq ft; $3.50
4. damplifier - ?; $115 for 40 sq ft; $2.88
5. RAAMmat BXT II ?; $115 - 37.5 sq ft; $3.07
6. B-quiet Ultimate - 0.39; $117 for 50 sq ft (1' x 50'); $2.34
7. RAAMmat BXT ?; $134 -15" x 50'; 62.5 sq ft, $2.14
8. eDead 80 - ? ; $2.34 sq ft
9. B-quiet extreme - 0.29; $91.5 for 50 sq ft; $1.83
10. Regular dynamat - 0.14; price?
11. McMaster Mineral - 0.13; $115 for 36 sq ft (4 - 24" x 54"); $2.78
12. McMaster EVA - 0.1; $81.8 for 48 sq ft (4 - 32" x 54"); $1.70
Product descriptions:
damplifier pro - viscoelastic butyl rubber 0.68 lbs/sq ft; Foil 6 mils 80 mils (2.0 mm) (12" x 20")
damplifier - Viscoelastic butyl rubber 0.48 lbs/sq ft 4 mils foil 50 mils (1.3mm) (12" x 24")
Dynamat xtreme - elastomeric butyl and aluminum 1.7 mm thick, 0.45 lg/sq ft
RAAMmat BXT II 4 mil soft aluminum finish, ~0.49 lb/sqft, 250 degree temp rating
RAAMmat BXT $134 premium Butyl mat 60 mil; 2 mill aluminum; 0.35 lb/sqft; 15" x 50'; 62.5 sq ft, 300F degree rated; $2.14
B-Quiet Ultimate butyl based is 1.6mm (60mil) thick, weighs 0.35 lb/sq. ft. comes in 1 foot wide 50 sq. ft. rolls
B-Quiet® Extreme - Rubberized asphalt; 1.15 mm (45 mil) weighs 0.30lb/sq. ft., comes in 1 foot wide rolls and is available in two sizes: 12 and 50 sq. ft. rolls
eDead 120 - ? 115 mils 1 mil litewarp 5 mil aluminum; Butyl Mat
eDead 80 -
McMastercar
install thread with pics
http://forums.vwvortex.com/zerothread?id=4078069
McMaster EVA ethylene vinyl acetate 2 mm (79 mil)
McMaster Mineral filled vinyl 50 mils (1.3 mm)
Thoughts: Well I think Number 4-6 seem like the best bang for your buck. I pull for the little guy so this sways me away from dynamat to RAAMat and Secondskinaudio. In the end Secondskinaudio interests me more so I'm thinking damplifier. However, my co-pilot is a tech nerd and she is thinking just go all the way for damplifier pro. I think there is a post else where about who makes the decision in a household.
