Let’s imagine, just for a moment that your day was going pretty well.
You were starting to pack for an upcoming Sportmobile trip, upgrading the gps maps, gather interesting trip files from the internet.
All was well until you realized that the kids were late for an appointment and the wife was gone with the other car. Leaping to your feet, you might imagine yourself yelling for the kids to hurry while calling the wife for directions and starting to ease the van out of the very snug garage. You would probably be halfway down the driveway when the slack on the extension cord runs out and you hear a crack and realize that you forgot to unplug the van from shore power.
How could you do something so boneheaded? Well, remember that if it weren’t for stupid mistakes, we may not make any mistakes at all.
In fact, this is a fairly minor problem as I determined on your behalf. Note that if you continue driving while plugged in, my statement may not hold true for you
A quick search on the internet shows the part number for the receptacle is Marinco 304EL-B, which is defined as a contoured 30A, 125V stainless steel receptacle.
Marinco is a boat equipment supplier and this is actually cataloged as a boat part.
There are similar parts such as the 303SSEL-B
http://www.rivermarinesupply.com/xca..._SS_Inlet.html
Note that this isn’t quite the same as the screw hole layout is different from the OEM 30A 125V power receptacle.
I couldn’t find any of the contoured Marinco 304EL-B locally and so Peter at SMB West was able to get me one within 2 days under $50 which was cheaper than my other options.
Once it arrived, the removal and replacement took 20 minutes including the pictures. I’d compare it to changing a light fixture with easy access and beautiful parts.
De-installation of the broken part is trivial. It is held to the Ford body by 3 sheet metal screws in a triangular pattern.
The rear cover is held by 2 screws, one to hold the cover and one as a power cable restraint.
Once off, the wires are accessible.
Loosening three color coded screws will give you access to the wires.
Reversing the process is simple and quick. The only tool you need is a phillips head screwdriver.
Hopefully this will be an example of the cost of inattention and you won't experience it
Now, back to packing....
