Re: torque maintenance-proper technique
I also don't know what the 'proper' sequence is to torque the lugs on an 8 bolt wheel. But, I will tell you what I do:
First, tighten them all hand tight with a socket and my hand. Then, start adjacent to the locking lugnut (you do have locks on those expensive wheels, don't you?) and tighten it to ~50 lb-ft. Then, directly across the wheel to 50. Skip a lug and tighten to 50, directly across the wheel to 50. Now tighten the locking lug to 140, directly across the wheel to 140, skip a lug and tighted to 140, directly across the wheel to 140. Jump to the next lug and 140, across to 140, skip a lug and 140, across the wheel to 140. Then I go around the wheel in a circle double checking all.
It may seem like overkill, but my engineering background tells me not to go too tight until I'm certain the wheel is flush to the hub. The handtight and 4 lugs at 50 do that. Then I tighten all the way, making sure I never tighten two adjacent nuts until I'm done.
