Old 09-07-2016, 09:51 AM   #1
winmag4582001's Avatar
Trans temp sensor, where to tap in?
Thinking about installing this to get a reading on what my tranny is running for temp.
https://www.amazon.com/gp/product/B0...A3Q5L29ROA0I31
Where do you all put the temp probe? Tap into the pan or T into the fluid line?
Thanks
winmag4582001 is offline   Reply With Quote
Old 09-07-2016, 12:07 PM   #2
1der's Avatar
How about a ScanGauge instead if your vehicle is OBD capable? The factory trans temp sensor is in the heart of the transmission and very accurate. Added benefit is the other readings you can get as well.
Beastie 3: 2002 7.3 EB Cargo: Agile TTB, CCV Mid Top, Custom Walk Through, Lots of stuff added. BlingMyRig.com
Old 09-07-2016, 12:19 PM   #3
Assuming your have a Ford, there's a sender port on the driver's side near the shift cable.
