Old 12-28-2011, 11:18 PM   #1
ANZAC's Avatar
Warn M12000 - Aluminess install
I will keep this post updated.
1. Follow this document to convert M12000 so it will fit into bumper and to be foot mounted
(pls contact Aluminess for any questions http://www.aluminess.com/about.htm)
this picture shows the winch with all the changes completed - NOTE FOUR MAIN BOLT HOLES ARE FACING DOWN, not forwards:
Notes:
a) rotate motor 180 deg - this is really straightforward, you need a 13mm wrench
b) re-index gearbox - the doc says it must be moved 1/3 turn, it is more like 1/5 of a turn, or 2/10 holes (see pictures)
c) mount solenoid box with the W upside down, and rotated forward so it clears the door. I tried to mount mine as close to vertical (but still kicked forward) otherwise the box of the solenoid box will hit the lid
detail of my solenoid wire routing:
d) careful with moving the cross brace rod --- make sure you put a piece of rubber or something to protect it when you hold it with pliers, I gouged mine a little because my pliers cut through the cloth I used which was folded double
2. I used two bolts at the rear - you're connecting into the rear plate which connects to the frame rails, definitely adding a lot of strength here. I used one washer on each side, between the winch and the back of the bumper box, and then installed the four bolts/washers from below. If you use anti-sieze as recommend in the instructions (given how much hassle I had with the old winch, I used it) be aware that this will impact your torque wrench readings, don't accidentally overtighten!
Sportsmobile-less.
Old 12-31-2011, 12:16 AM   #2
ANZAC's Avatar
Re: Warn M12000 - Aluminess install
The positive cable was a bit short on my install, just something to keep an eye on.
Sportsmobile-less.
Old 12-31-2011, 07:41 AM   #3
Gnarvan's Avatar
Thanks for the pic's.
The mod process looks pretty simple and straight forward.
I'm still trying to decide on which winch to purchase. The Warn M12000 install looks pretty simple. It might be a little more complicated to install the SuperWinch Talon 12.5 SR. Remote locating the solenoids on the SuperWinch may require making new cables.
Thor is out of the shop for another week and I still haven't been able to talk to him about the two winches. I did get a forwarded e-mail from him where he answered some of my questions. He prefers the SuperWinch. Something to do with the stronger planetary gears and the location of the brake being more synthetic rope friendly.
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 12-31-2011, 10:24 AM   #4
ANZAC's Avatar
More pics:
fairlead roller with Viking delrin rollers, and 2 coats of Rustoleum American Accents (?) Canyon Black, color recommended by Aluminess. Note I transferred the warning sticker
with synthetic rope installed, I got the thimble and the bumper so you can snug it up:
I still need to zip tie the cables, see if I can get a bit more length on the positive, and load up the line per the Warn instructions.
Sportsmobile-less.
Old 12-31-2011, 04:42 PM   #5
Where did you attach the + and - ?
Old 12-31-2011, 10:07 PM   #6
ANZAC's Avatar
Directly to van battery --- cables go out thru rectangular slot in back of bumper, under radiator and up next to battery.
On the winch, + goes to a terminal in the solenoid box, and - goes to the "motor ground" terminal on the backside of the motor. (the winch comes with the power cables connected to the correct places)
Sportsmobile-less.
Old 12-31-2011, 11:48 PM   #7
larrie's Avatar
Nice looking install. Good way to finish out the year.
Larrie
89 Ford 2WD penthouse
Larrie
Old 01-01-2012, 02:30 PM   #8
I did almost the same, except ground is connected directly to the battery (-). Which I'm pretty sure the instructions from warn said to do? I do remember it stating not to ground to the chassis. I actually routed the leads through the rectangular slot below the pass-side headlight, then up behind the headlight.
I did end up upgrading to optimas, because I wasn't happy how fast battery output dropped when doing a full-load pull, even with the motor running.
Old 01-01-2012, 03:28 PM   #9
One of the reasons I upgraded the alternator. My winch caused the computer to throw a code when I was jerking some guy out. I forgot to rev the engine but at that time I also had the crummy Ford batteries that came with the van.
Old 01-01-2012, 03:36 PM   #10
ANZAC's Avatar
Yes at the battery end both cables connect directly to the battery as per the instructions.
Sportsmobile-less.
TumbleWeed
Sarah
Van22
Van22
