The trip to Baja in November necessitated a few repairs on the rig after returning home. For one, the larger sway bar that was installed a few years ago needed to be re-welded to the mount after it broke off.
Since I really liked how much better it felt off road without the sway bar connected, I decided this go around to have Boulder Off Road add disconnects. A new drag link end was also installed. Nice!
Other issues were a few leaks that had sprung up, the left front axle seal and the rear pinion. I had BOR replace both front inner axle seals, also installed an improved outer seal to help keep dust out.
The rear pinion seeping is another issue altogether, it could mean the bearings are going and have some play. There are 2 ways to address this, tear down the axle and replace all bearings and seals or get a full float. I’ve decided it’s time for a full float. BOR has sourced an E-series D60 axle for me that is currently torn down and at the blasters. It will be built up using all new gears, 35 spline chromoly axles cut to fit and a Detroit Truetrac. Looking forward to it!
SMB RB50 w/CCV top
Quigley 4X4 w/Deavers & Agile RIP kit
