Been having a problem with the window washer sprayer on the drivers side. The fluid just dribbles out. Removed the wiper arms and the cowl. It was not a problem at the nozzle. Traced the hose back and found this.
Looks like the Splitter was rubbing against something inside the fresh air intake. Was headed to the local auto parts store to see if they had something like it. Home Depot is on the way so decided to stop to get some other items while I was out. As I was walking down the plumbing aisle I passed the irrigation section. A ten pack of these caught my eye.
Same diameter hose. I installed it and now the fluid sprays to the top of the windshield.
When I removed the cowl the gasket at the top that seals against the windshield disintegrated. Called the local Ford dealer to see if they had one. Turns out to get a new gasket you need to buy the cowl. Went back to HD and found a roll of rubber automotive door gasket that was the same height as the crumbled gasket. Cleaned off the old gasket and adhesive and stuck the new one on. Now have a new seal and working sprayer.
